year of platform for motor swap
I have been a long time fan of the GTO's and ive finally started looking for one. Im actually not against buying a higher mileage one as im looking for a car to yank the motor out of. I have a L92 w/ 20k on it and the #1 intake valve just barely kissed the piston, only hard enough to take the carbon off the piston, and bend the valve so slghtly. So LS3 intake valves, convention cam and a shave on the heads, voila!! 550 hp ls3 for pennies. Because im looking to swap motors, an LS1 car seems like a better starting point because of a WAY lower purchase price. Now I know that the brakes and rear were upgraded on the later models, but im not building a race car, might hit the strip just to see what the motor would do but not often. Is there any other reason besides those that a later car is a better platform for the swap? The LS1 goats are just way more affordable, especially when I plan on tearing the motor out and selling it. Not worried about any of the asthetic upgrades on later models either, mostly anything related to drivetrain and chassis.
I would go with an 04 if i was in your position, they can be had for mad cheap with a blown motor or no motor, or hell even higher mileage.
Then just upgrade the brakes if you want an your about set other then looks wise.
so nothing comes to mind other than the rear and brakes as far as that stuff goes then, and are the stock '04 rears good for a street beating in a DD? Thanks for your input too btw!
Im fairly sure the rears were the same in all years.
I had warranty replace A LOT of my rear, and keep in mind all of this was before 30k and at bone stock power levels, like differential, axle shaft, and differential seals. You may want to upgrade that or at least plan on it with an LS3.
i think the 06.maybe 05/06 had better axles. not 100% on that though. still not enough to make up the price difference. however it is easier to install dual split exit exhaust on the 05/06. they do look better all around, but yes the o4 is better budget car. im an 04 owner lol
I also thought the 05-06s had stouter axles. However I recently read a thread by someone who measured both and 04s and an 06 cars axles and found them to be dimensionally the same.
I was surprised as that was a rumor I had heard for years now.
I think for most any performance use, aftermarket axles are a great idea for our cars.
--Glenn
--Glenn
so just out of curiousity, the only visuals upgrades on the 05+ was the larger wheels, hood scoops, tail lights and rear valance and the optional factory appearance package or whatever that fancy front bumper was called right? other than that, the sheetmetal is all the same right? trunk, roof, quarters etc?
As for axles (or half shafts if you prefer), the early 04 had smaller axles and CV joints. At some point mid year they changed to the same as 05/06. Of course, the 05/06 had the LS2 and also the 4L65E trans compared to the 04 LS1 and 4L60E (The manual M6 stayed the same).
I stand corrected on a few items! thanks. Well if I find a nice '04 car ill probably jump on it and worry about the rear once the motor is in. And shouldnt have an issue with a trans, its going to have to be a M6. ive been driving an auto for the last 5 years and I like rowing my gears
I believe the 06 has lighted steering wheel controls, and also a place to rest your foot next to the clutch pedal in m6 versions. my 04 does not, so I either hover the clutch with my left foot, or tuck it away behind the pedal. in my opinion the 04 is a good budget car. the 05 is improved, but if I had the $$ for an 05, I would be looking for an 06..
