Gen 5 Camaro External Bolt-On Tech - JBA Long Tube Jet-Hot Coated Blow Out!!!
JET-HOT
07-06-2010, 04:16 PM
Our Christmas In July Sale Is On!!! Sale Ends July 23rd!!! Hurry and Get Your Order In.
2010 Camaro JBA Long Tube Header Sale!
JBA long tube headers are dyno and race proven to deliver the greatest possible increase in horsepower and torque throughout the RPM range. All JBA long tube headers feature large mandrel-bent stainless steel primary tubes, oversized exhaust ports, extra thick 3/8" one piece flanges, and patented JBA Firecone merged collectors for smooth flow. Each system is designed to give the maximum amount of ground clearance possible so lowered cars do not drag the collectors on speed bumps. Each system includes high quality hardware and thorough instructions for a professional no-leak installation.
Features:
3/8" thick CNC laser-cut flanges
Patented JBA Firecone merged collector
02 sensor provisions
Large diameter mandrel-bent stainless steel primary tubes
Oversized exhaust ports
Benefits:
Prevents leaks caused by warping
Increased hp/tq, improved exhaust scavenging
Standard on EFI headers for proper connection
Maximum flow and high RPM efficiency
Accommodates ported cylinder heads
All JBA headers feature stainless steel construction for maximum durability. Stainless steel is stronger than mild steel and minimizes exhaust noise. For street to severe-duty applications.
Headers
6812S $949.95 SHIPPED
Stainless Steel coated with JET-HOT's Sterling Silver Finish
1-3/4" Primary Tubes
3" Collector
6813S $949.95 SHIPPED
1-7/8" Primary Tubes
3" Collector
Mid Pipes
6812SD(3" Off-road (3" to 2.5") $279.95(COATED)
6812SDC(3" with cats (3" to 2.5") $549.95(COATED)
6813SD(3" Off-road (3" to 3") $279.95(COATED)
6813SDC(3" Off-road wcats (3" to 3") $549.95(COATED)
Axel Back
2-1/2" Axle-back w/ 4" Dual Wall tips
40-3112 $599.25(COATED)
Cat Back
3" Cat-back System w/ 4" Dual Wall tips (3" to 3")
40-3113 $909.25(COATED)
3" Cat-back System w/ 4" Dual Wall tips (2.5" to 3")
40-3114 $909.25(COATED)
Want to upgrade to EXTREME STERLING? EXTREME STERLING can withstand temps up to 1,700ºF. This amazing finish normally cuts down about 400ºF on the skin temperature of pipes. This coating is great for mild turbocharged or supercharges applications, or on pipes that have turned grey with other silver finishes. PM me or call us for details!
Dont Have A 2010 Camaro? Thats Ok Call Us Today For Your Make And We Will Review What JBA Has To Offer!!!
