Anyone that used pro-gram main caps to convert to 4 bolt
I have a 96 LT1 2 bolt block that I want to convert to either 4 bolt straight or splayed mains. Don't know if this matters but I would like to continue using my windage tray and oil level. There is several caps I can choose from and I'm a bit confused. So I was wondering which ones did you use to convert your lt1 block to 4 bolt. Here is the website. Part number would help alot. Thanks. http://www.pro-gram.com/catalog.jsp
I used splayed programs. I wound up calling them to see which one fit my app best. There is one set that does not retain use of your dipstick from what the guy was saying.
I am using a canton 242t pan also. I believe to retain your stock Windage tray is dependent on your hardware you use to attach your caps.
Does anyone use the SEARCH function?
You asked the same thing here
https://ls1tech.com/forums/lt1-lt4-m...continued.html
