computer issues
Old 07-06-2010, 09:07 PM
lq4pwns's Avatar
Default computer issues
I am building a 5.3 rx7, and am having a few problems. I have a modded harness, and have everything hooked up properly. My issues started when I tried to prime the fuel pump before initial start. I turned to key on, and nothing. I checked for power from the signal wire with a negative result (key on) So then I checked for power directly from the computer to the fuel pump signal wire, and nothing again. I became concerned about the computer as I double checked all pcm power and ground wires to the computer all with good results, and then checked the cel wire with a tester light with negative results. So, as an amatuer wiring guy, I have narrowed it down to the computer.
If anyone has any other ideas, please toss them around. I know there are many variables, so I will answer any questions to help myself and others.
Thanks!
