gen 1 sbc in 94 camaro
OK im doing a buit 355 4 bolt main gen one sbc in my 94 z ....i looked for a build thread but no luck ...
im trying to find out wat headers to use and motor mounts ect
its a 355 going through a 2 speed power glide ..
any help would be great
LT1 headers for a 4th gen work just fine. The SBC uses different mounting holes than a LT1 due to the A/C compressor rear mount on a LT1. 2 holes will line up for sure with stock motor mounts. The third hole in the lower back may be able to be used depending on your block and if that pad is drilled and tapped.
