Molding residue removal??
hey guys,
I just removed my "trans am" molding and the two sided tape is really on the door good. Anything I could spray on them to loosen it up for easier removal... any hints on getting this crap off would be appreciated. By the way I removed the door trim and it wasn't half as bad as these TA door emblems!
Re: Molding residue removal??
Check with your local body & paint supply store, they should have adhesive remover in the spray or quart can. You can also try heating the residue with a hair dryer and spraying some PB Blaster ( AutoZone ) on it and wiping it down.
Al
P.S. They also make a wheel that you put on a drill but I don't advise that.
Al
