how long - balancer installer
Old 07-08-2010, 06:26 PM
Jimbo1367's Avatar
Default how long - balancer installer
I was wondering how long of a piece of 16mm x 2.0mm allthread do I need to install a LSx balancer (LY6)
thanks,
Jim
Old 07-08-2010, 06:30 PM
Rick Speed's Avatar
mines about 10" long but it doesn't need to be
Old 07-08-2010, 06:47 PM
Jimbo1367's Avatar
I am wondering how long should be the minimum in length? I am on vacation so I can not measure it. I was hoping to find out and order it so it will be delivered before I get home.
thanks,
Jim
Old 07-08-2010, 07:19 PM
Pocket's Avatar
Get longer than necessary and cut it down later. What works for some people wont always work for others, especially with improvised tools like this
Old 07-08-2010, 07:30 PM
Jimbo1367's Avatar
thats my problem. I am having a hard time finding it. I have found fully threaded bolts. Up to 150mm. I just need a minimum though. I will have to wait longer for threaded rod. WHich I don't want to do.
thanks,
Jim
Jimbo1367's Avatar
thanks,
Jim
Old 07-09-2010, 06:30 AM
97s10ls's Avatar
Try Mcmaster-Carr that place has everything. They have it web site is pretty easy to navigate also
Old 07-09-2010, 06:58 AM
flame's Avatar
I got an ARP bolt for the crank and it is long enough to pull it on
Old 07-09-2010, 11:36 AM
Jimbo1367's Avatar
does this bolt engage the threads much? I would think if it does, it would "bottom out".
thanks,
Jim
Old 07-09-2010, 11:54 AM
bczee's Avatar
I just needs to be about and 1" to 2" longer than a stock balancer bolt. I found a bolt that was about 5" that worked with my LS1 balancer. Might need a bit longer one for a Truck Balancer?.
Remember to use a few washers and some grease to help make it turn a bit easier.
Old 07-09-2010, 12:01 PM
Jimbo1367's Avatar
Default McMAster-Carr
Thanks. I always forget to check them. My order was just placed. I wish they'd show shipping charges though. I hope my shipping doesn't equal the rod & nuts price.
thanks,
Jim
Old 07-09-2010, 12:20 PM
Jim_PA's Avatar
I just warmed it up with a propane torch and slid right on by hand.
You could probably boil it in a pot of water and get the same result.
Old 07-09-2010, 01:04 PM
Jimbo1367's Avatar
thats a idea too. LOL. I should of thought of that concidering us Sea-Doo guys always put our wear rings (jet-pump) in the freezer prior to installing them.
Once I am home from vacation, I will install the balancer and sell whatever I have left from my threaded rod/nuts for people who don't want to spend $45.oo from the LS1/tools member.
Old 07-12-2010, 11:33 AM
flame's Avatar
thanks,
Jim
It has a thick washer so I took it off to get the balancer started and then put back on and tightened it up. Its the bolt listed for an LS1 so it is the proper length.
Quick Reply: how long - balancer installer
