What to do with rust inside the frame?
Guys that sandblast or sand your frame on your projects, what do you do with the rust inside a boxed frame? Did you use any special tools or anything to get rid of it? I'm getting back to work on my project and I was wondering what you guys are doing. This will be on my 2nd gen Trans Am, any help is appreciated, thanks.
I had a mouse nest inside mine. A little carb cleaner and torch, add some compressed air to give it some oxygen and that was that. Then I took a brake cleaner spray can tip with straw, put it on a can of rust convertor and hosed it down. When using that tip, the "paint" comes out like a fire hose so be prepared. I had enough holes to access most of the inside of what was left of the stock frame. The front and rear were fabricated. I also "fire hosed" the other body areas I couldn't get at.
I'd recommend a rust converting paint rather than just the convertor only spray. You get a thicker coating.
http://www.eastwood.com/internal-fra...ay-nozzle.html
I used a cheap yard sprayer (like the ones you put weed killer or bug spray into) with some POR15 in it. I added a long piece of clean tube to it with some hose clamps and then clamped the sprayer nozzle onto the end of the new tube (basically made a really long spray nozzle). Pumped it up a few times, placed the nozzle all the way into the frame rail, hit the trigger, and pulled the hose out as it sprayed. Voila, no more rust problem. You might want to blow out the frame with an air hose first, though.
Be very careful using brake cleaner or other similar around any sort of flame:
http://www.brewracingframes.com/id75.htm
Matt's POR15 suggestion is a good one. Don't even need to bother with getting rid of the rust in there first.
Pat
Pat
Pat
Pat
