Which Tire will perform better with SS Yank 3600
I just ordered my converter from Dave at Yank the other day and currently i have a set of Mickey Thompson ET Street Drag Radials that are 295/55/15<27.8>
My previous tire was a 315/35/17<25.8> Nitto E/P and i ran a best of 13.04 @ 107.88. This was without a converter.
Once i went to the track with the the 27.8 inch tires i Lost 5mph<102.46> and my 60ft's were nothing to speak about.
So my question is should i go to a 275/50/15 DR <26.0> or should i keep the 27.8 inch DR's?
Thanks for all your thoughts...
Tire?
Thanks for your thoughts,however i have sold the 17 inch set of wheels and im running with 15 inch RaceStar wheels now so im sort of stuck.do i keep the 27.8 tires or sell them and go to a 26.0 tire??
Thanks again for your time
Tires
Great new's i sold the tires on ebay and ordered the 275/50/15's M/T Drag Radials...
My converter from Yank gets installed on the 27th of this month.I will take the new rubber and SS 3,600 Yank to the track on the 30th...
I will hopefully update my signature with a better ET and 60ft time....
Thanks for all your inputs!
ss Yank 3,600
Thats approx the time i was told that i would gain with the converter...
I hope thats true because they are not Cheap...
My best has been a 13.04 im hoping with the 26 inch dr's and the converter i can cut that to a 12.60 or Better lol
Yank ss4000 and 373's . My previous runs were at -85 d.a. . For my runs with the new stall it was @ +1428 da . My converter should have netted a 8 tenth gain or better if the air was the same as last time .
Yes , Stock 10 bolt with motive 373's .Running 315 35 17 Nitto 555r's ( Drag radials ) on heavy OE ZR1 wheels . My best 60 ft is only a 1.72 ( 3 times in a row ) .I hoping my new LT headers ,removing the ft sway bar and a little weight reduction will help my 60 ft and et .
I have a set 0f 1 3/4 hooker headers ans a texas speed catted y pipe . Im running a Magnaflow cat back right now . Its perfect for what I wanted . Quiet when cruising , but sounds great when Im in the throttle .
