Need throttle cable.
Its a 97z. i need options on throttle cables. The dealer says the part is discontinued. Is there anywhere i can find one gm or aftermarket. Part numbers would be greatly appreciated.
thanks
Ryan Gash
thanks
Ryan Gash
The following users liked this post:
Scotty Hill (03-16-2021)
I see your over in Bethlehem, I'm down below Quakertown. I make my way up there for Musik Fest every year and hit up some of the local bars and the Sands casino once every couple months.
OP, the '97 cables are a pain to come by but I was able to buy two used ones off ebay, maybe take a look and see if any are on there. The '97's are actually called accelerator cables not throttle cables like the other years so keep that in mind when searching, part# is 12554852.
EDIT: Here you go, says it was removed from a '97 Z28, non TCS and is in good condition:
http://cgi.ebay.com/ebaymotors/NON-t...Q5fAccessories
both are the same length. only thing that was different between the two was the end that goes into the bracket on the manifold. It's somewhat different in design but still fits in the bracket. the bracket is the same for 93-97 lt1's.
yea i'm right up the road from musicfest.
