How to Rebuild a 12 bolt
Old 07-09-2010, 10:09 PM
tsquared38016's Avatar
Default How to Rebuild a 12 bolt
Anyone have any links or information to step by step rebuild guide for a GM 12 bolt in a first gen?
Old 07-10-2010, 03:16 AM
98BlkBrd's Avatar
ive been asking the same thing....if you get some good lit or info could you send it my way as well
Old 07-10-2010, 08:43 AM
fleetmgr's Avatar
For the most part, the same as a 10 bolt...just bigger.
Old 07-10-2010, 12:11 PM
supermouse4's Avatar
Hot Rod Magazine had an article on how to rebuild a 12 bolt. Perform a search on their web site and it should help out.
Old 07-10-2010, 02:08 PM
Mustang Hat'r 2's Avatar
Buy in extra pinion bearing and hone it out so it slids on and off. You can set your pinion shim with that and get the solid crush sleeve. Haynes manual is a good referance.
Jay
Old 07-13-2010, 11:10 AM
Jawsgear's Avatar
http://www.jawsgear.com/files/Instal...structions.pdf
Old 07-13-2010, 02:42 PM
98BlkBrd's Avatar
JAWS... thanks for the PDF. saved to PC
Old 07-13-2010, 03:22 PM
Great information. Thanks all for the help.
Old 07-13-2010, 04:41 PM
Jawsgear's Avatar
They are Yukon Instructions which I helped write, hence the name Jeff Wilson on the cover. I do not car for the Yukon Line but the info is top notch and on the money. Glad to help.
