M12 T56 Rebuild Question
I have an issue with the large tapered bearing on the main shaft. During disassembly, the old bearing came off without using a press, (using only the splitter) and the new bearing goes back on without a press. Has anybody else had this issue? Do I need to replace the mainshaft? The bearing I have is Timken# 25572
Alex
Alex
Alex
Alex
Correct. Right in front of first gear. The manual on this site that I was going by says to use a press to remove and reinstall the bearing. So according to what you're saying, with the o-ring removed I should be able to remove the old bearing and install a new one by hand? I just want to make sure because I don't want to put it back together and have it wear on the shaft and cause other issues.
