Conversions & Hybrids - 02 sensor problem?
tryinggenIII
07-10-2010, 06:09 PM
hi all i am having a problem with my swap (2006 5.3l/4l60e) into a 1974 chevy truck. I got the bosch universal o2 sensors (black, white, white, grey) and i connected the wiring using an online bosch 02 sensor page. I connected both sensors as black=purple, grey=tan, and white=dark brown, white= pink. my truck runs rich and throws codes p0172 and p0174. when i get the live data only bank 1 reads. The maf and bank 2 doesn't read at all. I disconnected both 02 sensors and the truck idles and responds well and the maf reads. Could i have done something wrong to the bank 2 sensor that would make it read/run this way? or? any help is greatly appreciated.
tryinggenIII
07-11-2010, 02:51 AM
anyone?
71ANTICARB
07-11-2010, 02:58 AM
What does the bosch page say the white wires are for having two maybe they are in the wrong position or maybe there is a bad connection on the bank 2. Have you checked for that. And I am getting ready to do a 6.0 swap why didn't you use the factory O2's.
Old Geezer
07-11-2010, 06:53 AM
Aftermkt harness?
1quickirocz
07-11-2010, 12:39 PM
try swapping the sensors to the oposite banks and see if the problem switches banks. I had a brand new out the box bosch o2 that was bad and caused the exact same prob. its either that or you have wires mixed up.
tryinggenIII
07-11-2010, 04:28 PM
ok i'll try switching them. I didnt use the factory 02's because they didnt come with my setup and werent available at any parts store.
tryinggenIII
07-11-2010, 04:36 PM
Aftermkt harness?
stock harness!
tryinggenIII
07-12-2010, 04:01 AM
OK it's all figured out. 1 point for the idiots at the parts store. One of my sensors was for a 2002 Chevy 5.3 (wrong one). My setup is out of a 2006 silverado. I believe that the difference is in grounding. I think all sensors 2003+are grounded by the Pcm and 99-02 are grounded through the sensor or some other external source. Anyways, I just added the new 2006 universal sensor and vrmmmm..... with no codes. Thank you everyone that to the time to help.
tryinggenIII
07-12-2010, 04:04 AM
The white wires aren't polarity based so they can be swapped between the two remaining wires. The grey is ground (low signal) and the black is high signal.
thedrill
07-12-2010, 08:57 AM
Brand Signal Ground Heater Heater
AC Delco Purple Tan Brown Brown
Bosch Black Grey White White
Delphi 1 Purple Tan Brown Brown
Delphi 2 Black Grey Purple Purple
Denso Blue White Black Black
Honda 1 White Green Black Black
Honda 2 Blue White Black Black
NTK Black Grey White White
Toyota Blue White Black Black
I think you need to connect the pink and black wires to the whites on the new sensor, purple to the black and the tan to the grey.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
