Camshaft suggestion for Carb'd 5.3
Old 07-11-2010, 01:48 AM
Pro-Tour Heavy Chevy's Avatar
Default Camshaft suggestion for Carb'd 5.3
Since most cams out there are ground for FI. What are the carb'd guys running. Was thinking of running the LS-6, but I hear the wide LSA isn't ideal for carb'd motors.
I'm Running (for know) a stock 5.3L Longblock w-Edelbrock Perf.RPM and Edelbrock 600 CFM carb.
200-4R trans w-2400 stall converter.
3.73 rear gears w-26 inch tire
It's going in a 71 Chevelle and will be a driver. looking for a cam with broad power band.
Was looking at Comp Cams XR273HR for good power and drivabilty.
Suggestions?
Old 07-11-2010, 08:26 AM
Mustang605's Avatar
I say go ahead & spend a few more dollars & get a custom ground cam...That's what I did & it isn't that much more than 1 off the shelf...that way you get exactly what you want & how you want it...Find a company that does them & let them know what your setup is & everything & they can make 1 just for you
Old 07-11-2010, 01:37 PM
Old School Heavy
speedtigger's Avatar
I have a near identical swap scenario going in my 65 Skylark. I did a lot of reading and also called comp cams and spoke to some of their tech guys. For my swap they suggested the XR275HR. When I questioned them further about the preferences of the carbed motors vs the fuel injection motors, here is what they said:
"I would use our part number 54-426-11 in this setup. This is a 3 bolt camshaft. There is not much difference in selecting a cam for a EFI or Carbureted LSX engine. They still typically like a little wider LSA and typically either a 111 or 112 for a carb setup are best. This is completely dependant on application though of course.
Aaron Mick
COMP Cams Technical Consultant"
I would consider Comp Cams as good of expert advice as I might find on this topic. So, for me, it is case closed. I will be using a good old off the shelf XR275HR. I bet your XR273HR is an excellent choice for your combo. It is almost the same cam only 2 degrees less duration and slightly less lift. Probably perfect for the 5.3.
Quick Reply: Camshaft suggestion for Carb'd 5.3
