General Maintenance & Repairs - Glove box keeps falling open...What now?
IROCthisZ28forLife
07-11-2010, 11:57 AM
Okay so here in NYC, we have the most AMAZING ROADS...As I was driving down one of our fine streets, I came across a MASSIVE hole, so I went to avoid it and hit another lesser hole. Glove box flew open and it bottomed pretty bad, I closed it and kept going.
Now every couple of minutes it falls open...Any ideas on what to do? Ive only found how to adjust the handle to open it. I want it to stay closed.
killagt
07-11-2010, 02:49 PM
ziptie:D
Drew24
07-12-2010, 01:38 PM
Check to make sure that the bracket screws are tight mine did the same thing and it turned out that there were two screws that came loose.
IROCthisZ28forLife
07-12-2010, 08:17 PM
Yeah they were all tight, I took apart the assembly then tried putting it back together and screwed up the spring part cause I didn't pay attention how it was originally on....
Snake_Skinner
07-16-2010, 03:36 AM
buy a new lock and re install
'99REDTA
01-12-2013, 02:09 PM
you ever fix it? mine does similar stuff, on hard bumps especially when its cold
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
