To do list: everyones got one.
Old 07-12-2010, 12:42 AM
Havoc1306's Avatar
Default To do list: everyones got one.
So now that I'm finally back in a financial position to fix all the little things that have gone wrong with my car during the time I was flat broke, I whipped up this little list. (In no particular order of importance)
1. Drivers side window motor or regulator is shot.
2. Exhaust rattle while idling warm.
3. Broken driver side seatbelt guide.
4. Cracked driver side door panel. (yeah mine too)
5. Antenna motor fried.
6. Burning a decent amount of oil.
Not Bad for a 2001 TA with almost 100k on it.
Now would anyone happen to have the parts numbers for the seatbelt guide(Ebony), door panel(Ebony), window motor/regulator, or the Antenna Motor?
More importantly anyone have any words of experience from fixing any similar issues to those on the list that they would like to share before I start poking around. Thanks for anything you guys can come up with.
Old 07-14-2010, 01:35 PM
Arc00TA's Avatar
Replace and get the hotwire kit
This is probably a bad cat, the ceramic is rattling in there
How did you break that? I think it just screws on the seat.
Replace it, I use armorall on mine they haven't cracked yet even in socal sun.
Are you sure the motor went bad, and not the antenna dried out of grease and is stuck?
Check your PCV system or look into upgrading to the LS6 style, that saved mine.
Here ya go, I got a long list for mine as well.
-Replace broken dash vent
-Replace The plastic part on the seatbelt buckle itself
-Fix shitty stereo wiring so I have more than one speaker
-Rebuild the rear end since its making bad noises
.... It goes on and on haha
Old 07-14-2010, 02:27 PM
Torchie94's Avatar
Replace my clutch
Replace my oil pump/pickup tube
Replace a few interior pieces
Get a new headunit since mine doesn't light up anymore
New speakers
New radials
And hook up my spray
Quite a long list haha
Old 07-14-2010, 04:13 PM
Rhin's Avatar
My list:
  • Strip Paint
  • Remove Rust
  • Add Body Filler, Prime, Paint
  • Electrical Component and Interior Swap
  • Engine Swap
  • M6 Install (Body has been cut appropriately)
  • Dispose of Donor Vehicles
  • Replace Rubber
  • Switch Over Front Clip
  • Have fun with my lS1 powered and front Clip 95 Hardtop
Old 07-15-2010, 01:12 AM
lethal bird's Avatar
repaint front bumper and side skirt
get a new hanger for exhaust
new dash pad
new driverside tail light
vht the crap out of them
Heads, cam, intake, BOTTLE!!!
Old 07-15-2010, 06:27 AM
drago1217's Avatar
Replce radials
Adjustable panhard bar (not centered after drop)
New sway bars (keep busting bushings)
Cracks in doors too but pointless to replace
New speakers in sail panels (changed last week already blown)
New rearend
Look on hot girls faces as you creep by..........priceless
Old 07-16-2010, 01:19 PM
Hartje's Avatar
new rear end
new get traction bits
new lower suspension
new front formula bumper
new paint
new wheels and tires
before completion of said list...
NEW DAILY DRIVER!
Old 07-16-2010, 03:59 PM
osuhog's Avatar
Bought my WS6 3 or 4 weeks ago now & started my list. The list is now nearly complete with my dyno tune scheduled for Monday morning!
1999 WS6 (Craigslist)
Whisper lid & K&N filter (LS1Tech)
K&N filter recharge kit (Advance)
TB bypass kit (Ebay)
Plugs, wires, header gaskets, 02 extensions (WS6 Store)
Air & EGR delete plates (WS6 Store)
Headlight gear (O'Reilly)
High beam lights (O'Reilly)
LS6 intake & ported TB (LS1Tech)
BMR weld-in subframe connectors (WS6 Store)
Random Technologies adjustable torque arm (LS1Tech)
J&M Hotpart lower control arms (LS1Tech)
New power antenna & adapter (Ebay)
Front end alignment (Pioneer Tire)
FLP headers & full Corsa exhaust (Craigslist)
Chrome hood & fender inserts (Ebay)
HID headlight/foglight conversion (LMC & DDM Tuning)
Rear end flush (Kwik Kar)
SLP Strut tower brace (LS1Tech - trade tips)
Silicone hose to fix y-pipe banging (O'Reilly)
New MAF sensor (LS1Tech)
B&M transmission cooler (WS6 Store)
Yank SS3200 stall converter (Craigslist)
Transmission fluid, filter, & shift kit (Transmissions Plus)
Rear main seal installed (Transmissions Plus)
Weather stripping to seal off ram air hood (Lowes)
sell intake, TB, air/egr, exhaust, LCA's, springs, lid, etc.
UMI LCA relocation brackets (Strano Parts)
Lakewood adjustable panhard bar (Ebay)
Chrome lug nuts (Ebay)
Rear wheel spacers (Ebay)
Front wheel spacers (Ebay)
2006 Corvette wheels & tires (Craigslist)
Bremco red caliper covers (Ebay)
Bilstein BTS-7501 lowering kit (LS1 Tech)
Dyno Tune (XP Racing)
Old 07-20-2010, 03:38 PM
Striker's Avatar
Oh Boy....
*just finished:*
-Door Panel Mod (no more cracking)
-Replaced Sealed Beam Unit
*things awaiting to be done*
-fix my miss aligned weather stripping
-Get Clutch Installed+new slave and pilot bearing
-ALL fluids flushed (brake, PS, rad, rear end, tranny)
-Fix the annoying scratches at the base of the windshield
Old 07-21-2010, 08:02 AM
DMax32284's Avatar
paint
clutch
rear end
heads
Old 07-21-2010, 09:31 AM
SilverV6Camaro's Avatar
Replace crackling door speakers
Replace cracked front sway bar
Replace burned out headlight/fogged up high beam
Replace heater and radiator hoses/flush coolant
Old 07-22-2010, 01:44 AM
sgm98ws6's Avatar
Replace rear tires
Fix driver side window
Intsall flowmaster merge with 3.5" cut out
reflash computer for the auto
Rebuild LS1
8.8 Conversion
Install drive shaft loop
Guess I will be busy this winter.
Old 07-23-2010, 11:43 PM
zamora7's Avatar
COPY AND PASTE
My list:
Strip Paint
Remove Rust
Suspension
LS1/M6 Install
Replace Rubber
Have fun with my lS1 powered 1980 TRANS AM
For my 2000 WS6, not before I finish the 2nd gen though
A/C
Antenna
Lowerind springs
Shocks
Adjustable panhard rod
SFC's
Cam
Sticky tires
Old 07-27-2010, 06:11 AM
WS.666's Avatar
Install New Wheels and Tires (17x13 Black ZR1s and 335/35/17 tires on rear)
Install Monster Stage 4 Clutch
Install Built T56
Install Carbon Fiber Driveshaft
Rebuilt Moser 9" (Seal between Third Member and Case is leaking)
Finish Nitrous Install (taken WAY too long to get that done)
Retune/Dyno Pulls for Nitrous
Serious Detail before Winter (might even get a professional to do it)
This winter while she sleeps in the garage:
Install 6LE Gauge Overlays
Send Gauge Cluster off to be recalibrated for 200mph 6LE Overlays
Remove Stock Seats
Remove Old Carpet
Remove Stock Front Seatbelts
Install Weld-in Wolfe 6-Point Roll Cage
Install New GM Carpet
Install 6LE Racing Seats
Install 5-Point Racing Harnesses
Depending on the money situation come winter, I may get a whole new stereo system installed...everything from Head Unit to Amp to Speakers, nothing extreme, just something that is able to handle the volume I like.
Old 07-27-2010, 03:34 PM
6LITEREATER's Avatar
Right now...
Install 6LE/McNord Overlays (they are from the LAST GP, not even the recent one )...
Install new carpet...
Get Seats embroidered...
Fix Transmission Mount...
Re-install Nitrous...
Install Shaker Air Box...
Hopefully soon...
Finish the targa and actually cut the roof...
Near future...
Get the McNord Dick Harrell style front bumper on and painted...
Get McNord Blended CME Valance rear bumper on and painted...
Get Trans-Am side skirts modified on and painted...
Old 08-09-2010, 08:26 PM
xBrian's Avatar
6LE's big brake kit
BLS headlights
Find why I'm idling low/rough
Driver and passenger door cracks.
Driver side mirror (just the glass part) rattles like crazy
LT1 radiator swap
Old 08-09-2010, 09:29 PM
mrrman's Avatar
just posted mine in my thread...
https://ls1tech.com/forums/pontiac-f...m-working.html
Old 08-09-2010, 10:05 PM
1998flamedCamaro's Avatar
New headliner
Fix Monsoon cd player (display not working)
Fix passenger seat belt loop
Fix little light above passenger side door controls
Basic tune up (fuel and air filter, plugs, wires, maybe a rad flush)
Quick Reply: To do list: everyones got one.
