New clutch won't engage Please Help!
Old 07-13-2010, 09:56 AM
Chronicle's Avatar
Default New clutch won't engage Please Help!
Well, I installed my new clutch package, and now I can shift into gear once, but after that I can't engage any other gear, ( for example, I can shift into first, but if I put the clutch in and shift into neutral, I can't shift back into 1st, or any other gear). We tried bleeding the system, but I think the person manning the clutch side was sloppy about it. Here's what I've got for hardware:
Monster Stage 3 Clutch kit (w/ 18lb Flywheel and new slave)
5k mile old Master cylinder with drill mod
143k old T-56 with fresh Dex III
Any ideas? I can answer any other questions if it will help.
Old 07-13-2010, 10:45 AM
SNLPerformance's Avatar
Sounds like you've got some air in the system... give us a call at the shop and we'll walk you through some things to get it diagnosed properly.
Old 07-13-2010, 11:15 AM
Chronicle's Avatar
Well, when I say the guy on the clutch was sloppy with the bleeding, basically he just jammed his foot on the pedal about 15 or so times, didn't take any time with it at all and definitely didn't let the clutch come back up all the way with each pump. I'm going to do it myself this time, and if we're still having issues I'll definitely call.
Old 07-13-2010, 11:30 AM
rabiddog's Avatar
Is the pedal firm or soft?
Old 07-13-2010, 11:47 AM
Yeah... that thing needs to be pressure bled and you'll more than likely not have anymore issues. This is a common issue when the clutch isn't bled properly which sounds like the case with your setup for sure.
Give us a call anyway and we'll go over any questions you may have.
Old 07-13-2010, 12:49 PM
ClutchExpert33's Avatar
If none of this works, you should take it back to factory.
Old 07-13-2010, 01:13 PM
LOL, great first post.
Old 07-14-2010, 08:18 AM
Chronicle's Avatar
Well, I've got everything in now, the clutch works, but it's almost impossible to shift into reverse. Will that be relieved by the break-in miles or is something wrong with when I put everything together?
Old 07-14-2010, 09:10 AM
Josh@Lashway's Avatar
hahaha +1
Old 07-14-2010, 11:07 AM
Have you called us yet to go over diagnosing this with you? We manufactured the unit, nobody is going to know the setup better than us.
Old 07-14-2010, 11:25 AM
Chronicle's Avatar
No I haven't, since the only time I get to work on it is usually between the times 8 and 11 PM =[
Old 07-14-2010, 11:30 AM
I just shot you a pm with my cell number, call me when you get off work and we'll get you taken care of.
Quick Reply: New clutch won't engage Please Help!
