Gen 5 Camaro External Bolt-On Tech - adding Oem RS headlamps to SS.
EDawg
07-13-2010, 07:00 PM
From what I have read it can't be done. Well I'm here to say it can be done. All the gm master techs said noway. it took some figuring but it's almost done. I had to make harness. But they are going to work like factory. If I get time I will post up some pictures.
Sam88Gta1
07-13-2010, 08:59 PM
You removed the factory SS headlight housing and replaced it with a RS light?
Do you have the factory SS housings?
SS 376
07-13-2010, 09:01 PM
Ok, so you added halos and HIDs in place of the stock halogens? Sounds good.
EDawg
07-13-2010, 09:51 PM
I replaced the factory headlamps w factory hid lamps. These do not plug up. I didn't want aftermarket lamps so I sucked it up and bought the factory hid lamps. About 700 a side. They would not plug up. Gm makes the car where it's not upgradable w factory parts. You change the harness and bcn module. And after programed still no lights. So I made a relays system and the lights work just like factory.
someday
07-14-2010, 09:03 PM
so y didn't u buy the RS from the start? bet u have 2 grand in it plus countless hrs, vs $1200 for the RS package...
EDawg
07-15-2010, 07:31 AM
Because I got a really sweet deal on my car. 2ss auto with 400 miles for 30k.
I have 1400 in the conversion
ss1129
07-15-2010, 11:59 AM
They actually make a decent looking aftermarket halo headlight for the camaro now. They are selling for $400 a set on ebay. I know its not factory, but its 1/4 of the cost.
Way to troll. Sometimes people don't do things because its the most fiscally responsible.
robsls1
07-26-2010, 10:00 AM
UGh they look horrible on the car. Seen some up close and it doesnt look nothing like the RS package. Looks like some flaky tube in the lights.
EDawg
07-27-2010, 08:37 PM
I agree. They way mine are hooked up the halo is the driving light and the low beam comes w it at night.
2002_Z28_Six_Speed
08-03-2010, 03:11 PM
Wow. I can't believe that GM made it so incompatible. That's crazy.
Hids at any cost are worth it though.
robsls1
08-05-2010, 08:32 AM
Give it time untill somebody designs a aftermarket harness to make this happen.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
