starting issues
Old 07-14-2010, 04:02 PM
JG25's Avatar
Angry starting issues
so i just bought a 02 z28 6speed. and for some reason it will not start sometimes. most of the time its after i drive it from work or when motor reaches normal opperating temp. but its also happened once when tryin to start it in the morning. i turn they key all the lights turn on but will not crank over. everything works fine.any 1 have any idea what it could be. let me know this prob is really annoying me lol
Old 07-14-2010, 04:36 PM
JG25's Avatar
o yea after a few trys the car will start right up. sometimes it will take me a few minutes to get it started. but it starts after a few trys
Old 07-14-2010, 04:53 PM
blade2222's Avatar
dose the security light go off after about 5 secs?
Old 07-14-2010, 04:59 PM
vetteboy99's Avatar
Did you check all of your fuses? Or maybe there is something wrong with your key. The chip might not be operating right.
Old 07-14-2010, 05:17 PM
JG25's Avatar
yea the security light goes off and the chip on the key is fine. ive tried both keys and samething no crank.
Old 07-14-2010, 05:28 PM
blade2222's Avatar
check the connections at the starter and clean them, had a bad connection at the starter that did this to me.
Old 07-18-2010, 02:04 PM
JG25's Avatar
yea im going to check that today. ill let you know how that goes. hopefully thats the problem.
Old 07-18-2010, 02:05 PM
JG25's Avatar
how can you tell if the chip is bad? its not loose or damaged. looks ok to me but that may be the problem
Old 07-19-2010, 08:53 AM
blade2222's Avatar
if the security light goes off it's not the pellet in the key.
Old 07-19-2010, 08:47 PM
JG25's Avatar
ohhh ok . yea the light goes off. the car was doin fine the last couple day and now when i go move the car to take the garbage out the car doesnt want to start.
