New LS1 Owners - Newbie Tech - SES light/ O2 Simulators
View Full Version : SES light/ O2 Simulators
Edrummr
01-19-2004, 03:13 PM
I put an ORY on my car a few months ago. At the time I didn't have OBDII oxygen simulators. As expected, the SES light came on.
Now that I have the O2 sims on, the light is not turning off. Should it or do I need to have a trouble code deleted from my PCM? Thanks.
Jabroni
01-19-2004, 03:35 PM
After awhile, the light should go out but it might not. Try resetting the PCM and see if that helps. Also, I had a sim go bad and it threw the SES for that. Make sure the sims are still good.
Edrummr
01-19-2004, 04:29 PM
OK, I'll give it some time and see what happens. I'll reset the PCM if the light persists. BTW, I purchased the O2 sims used locally. I don't have any reson to believe they didn't work before I got them but one or both could be bad. Is there any way I might 'make sure' the sims are good?
Thanks.
