RAM Clutch
RAM Clutch
The ram clutch from TSP any good? the one rated up to 600 hp? i want a clutch that will last thru a good beating! I drive normal weekly, but every now and then i have a score to settle, or another ricer to shut up
You are going to get a lot of mixed opinions on this because of the nature of what a clutch is. From basically any company you will pretty much always going to find premature failures and other issues. Probably the majority are from installation problems, the rest being either a manufacturing defect or one of the other millions of ways mechanical parts can fail. I use RAM clutches and know others that have. I find them to generally be good clutches and like that they don't need a break in (or at least most don't). Granted my car is an LT1, but for what its worth mine has taken about 20,000 not so easy miles still grabbing like a clamp. The first clutch dump was at about 80 miles. YMMV
I had a ram in my old LT1 and loved it.... The one for the LS1 you are talking about is garbage though! I went through 2 within 6 months through the warranty and they wouldn’t replace it again after that. I only ended up getting 1/2 my money back for it and bought a centerforce dual friction after that. It has been in there for about 4 years now and still works great. I will never buy Ram again...
Yeah it was a freakin nightmare and a half! They tried to come up with every reason they could think of for why it kept failing but when they tried to blame me for installing a shim that came with the damn thing I had enough and asked to just get my money back. The only reason I settled for 1/2 my money was to just get it done with cuz I was literally drained from the whole thing.
Depending on how much power you are putting down I would recommend a Monster Level 2 or a Level 3.
Give me a call at the shop and we can go over your options on the phone.
Matt
817-750-2000
Matt
817-750-2000
Ok guys... monster! So which one can handle the worst beating from the mods in my sig? I have no clue what the real dyno numbers are. too much debate between all the dynos in Little Rock.....gotta be less than 450whp right?
