Decent welder for simply tacking?
I figured this would be an appropriate place for this question as it deals with exhaust. Looking to mock up some exhaust and need a welder to use simply for tacking. I don't need anything special at all, just something simple, easy to use, that I can tack some headers, x-pipe, etc etc. What would you suggest? Thanks!
-Jon
-Jon
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
I would suggest visiting your local Home Depot and picking up a Lincoln Welder. They're relatively cheap and easy to use. You will also want to pick up shielding gas from your local welding supply shop.
Also Mod please move to tools and fabrication. Superman09 you might get more responses with this thread being placed there. Hope this helps
Moderator
For that, I'd say the cheapest 110V flux cored wire gun
you can find.
I've got one of those and subsequently haven't pulled
the big MIG out in years. But have used the cheapo
plenty, including welding up the K-member on-car.
you can find.
