kooks header and catted y install question
Old 07-16-2010, 11:45 AM
'01-B4C's Avatar
Default kooks header and catted y install question
new kooks headers and catted y just arrived. my question to anyone with this setup is....are the supplied gaskets any good and the headers came with a paper saying some adapter is needed 4 my install on a 01 camaro. i also need to repalce motor mounts with my new engine.any suggestions on brand thanks in advance guys
Old 07-16-2010, 11:53 AM
98hc4mula's Avatar
us the polyurethane motor mounts...many sponsors sell them. I used the gaskets provided by ARH so I would think kooks are ok to use. I have not had a problem with them.
make sure you do the mounts first then the headers.....they are kinda tricky to get to.
good luck
Old 07-16-2010, 12:25 PM
'01-B4C's Avatar
thanks man, i was just concerned about the gaskets...they look sorta cheap and since im doin an engine swap .. i just wanted to do it right the first time and not have to go back later. the adapter thing also had me concerned thanks again
Old 07-18-2010, 03:34 AM
joblo1978's Avatar
Those felt gaskets are garbage!
Reuse the multi layered steel stock ones if they're in good shape or get new stock gaskets. I guarantee you'll be pulling the headers off again soon to replace the gaskets if you don't.
