Vehicle Classifieds - 1999 chevrolet camaro ss,blk on blk M6,texas speed built mint,21k orig.doc.miles,$$$
standup95
07-17-2010, 01:35 AM
ok up for sale is one of the cleanest,lowest mile camaro's you will ever come across,not a ding scratch or chip on the car rarely washed,mostly spray wax,maybe seen water 5 times,completly babied,climate controlled garage stored all year round car is a 10 out of 10!!!,car is never ever driven thats why i am finally came to the conclusion to put it up for sale can easily win car shows anywhere it would go,the car only has 21,000 original miles on the body and about 2,000 on everything else,have alll reciepts,paperwork,and clean title in hand,engine alone has about $13,000 into all professionally built by texas speed and performance in texas, it with every single part being new when built back in 2007 and that will show you how much i have drive the car,car is comes complete with ac and all the accessories that were removed for build etc...,back seats included,original silver zr1 ss wheels with tires,and a couple more things im sure im forgetting,ok now to everything the car has into it:
ENGINE-EVERYTHING NEW!!!!CAR IS BUILT TO HANDLE TURBO,SUPERCHARGER OR NITROUS RIGHT NOW WITH THIS SETUP
-LS1 ENGINE BLOCK,ALL HONED,BALACENED,BLEPRINTED ENGINE
-LS1 3.622 STROKE CRANKSHAFT
-SCAT LS1 H BEAM 6.125 CONNECTING RODS,.927 WRIST PINS
-DIAMOND RACING LS1 FORGED FLAT TOP WITH -2CC VALVE RELIEFS,3.905 BORE,3.622 STROKE,6.125 ROD LENGTH,.927X2.50 WRIST PINS
-LS2 CAM BEARINS
-CLEVITE ROD BEARINGS
-PATRIOT CNC HEADS
-COMP CAM
-GM LIFTERS
-MANLEY PUSHRODS
-SLP PORTED LS6 OIL PUMP
-CV PRODUCTS TIMING CHAIN
-BBK PORTED THROTTLE BODY
-SLP PORTED LS6 INTAKE MANIFOLD
-ALL GM GASKETS AND SEAL
-ARP HEAD STUDS
-HOOKER COATED LONGTUBE HEADERS AND OFF ROAD Y PIPE
-TEXAS SPEED COMPTUTER TUNE THEN EASY FIRST BREAK IN DYNO TUNE AT 405RWHP AND 393LB FT OF TORQUE,HAS MUCH MORE LEFT IN IT,JUST A BREAK IN TUNE BEFORE I WAS GONNA PUT A SUPERCHARGER ON IT,AND THEN WAS TOLD WOULD BE IN THE 700++ HP RANGE!!
SUSPENSION:
-BMR TUBULAR K MEMBER AND UPPER AND LOWER A ARMS
-FLAMING RIVER MANUAL STEERING RACK(SO CAR HAS NO POWER STEERING AT THE MOMENT BT CAN EASILY BE PUT BACK ON)
-SPOHN SWAY BARS AND STRUT TOWER BRACE
-SPHONH SAFTY LOOP AND TUBULAR TRACK TORQUE ARM
-KENNY BROWN DIAMOND SUBFRAME CONNECTORS
-BMR REAR LOWER CONTROL ARMS AND PANHARD BAR
-SPOHN REAR SWAY BAR
-ALL NEW POLYURATHANE BUSHINGS EVERYWHERE(DONT ASK ME WHY I DID EVERYTHING WHEN THE CAR ONLY HAS 21,000 ORIGINAL MILES,U COULD PROBABLY CALL ME CRAZY IF YOUD LIKE :))
TRANS AND REAREND:
-FRESHENDED UP T56 TRANS,SHIFT FORKS ETC...
-SPEC STAE 2 CLUTCH
-FIDANZA FLYWHEELS
-GM THROW OUT BEARING
MOTIVE 373 GEARS 10 BOLT WITH TA REAR COVER
WHEELS AND TIRES
-GREG WELD FRONTS 15X4,SUMMIT STARS REAR,MT FRONT TIRES,BF GOODRICH DRAG RADIALS REAR,275
-STOCK CAMARO SS ZR1 WHEELS,17X9 SILVER FINISH WITH TIRES,275'S ALL AROUND
AGAIN,CAR IS ABSOLUTLY SPOTLESS INSDIE AND OUT,CLEANEST F BODY I HAVE EVER SEEN HANDS DOWN,CAR ALSO HAS,NEW STARTER,ALTERNATOR,ETC.....LIKE I SAID,CRAZY LOL,I GO A LITTLE OVERBOARD SOMETIMES :),BUT I AM CONFIDENT TO SAY THAT THERE IS NO DISAPPOINTMENTS WITH THIS CAR,10 OUT OF 10,EMAIL ME AT CHOZNZ51@GMAIL.COM FOR MORE INFO IF NEEDED,INTERIOR IS ALL STOCK AS WELL,NO AFTERMARKET GAUGES,ETC,FACTORY MONSOON IS STEREO AS WELL,GOOD LUCK AND HAPPY BIDDING!!!!!IM SURE IM FORGETTING STFF AS WELL,HAVE ALL RECIEPTS AND DYNO SHEETS AS WELL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
PLEASE EMAIL ME FOR PICS AT CHOZNZ51@GMAIL.COM,THANKS IT WOULDN LET ME POST THE PICS CAUSE THEY WERE TOO BIG
standup95
07-18-2010, 12:19 AM
Ebay id#250665678613,over 20 pics and reciepts,car is immaculate
standup95
07-20-2010, 09:41 AM
tttop
1-HOT-SS
07-20-2010, 04:16 PM
could you send pics to maxterc@yahoo.com
thanx, max
