Gen 5 Camaro Internal Engine Tech - LS3 No OIL PSI
acowherd
07-17-2010, 06:00 AM
I have a modded ls3, that just lost all oil pressure. It should be the check valve inside the oil pump. GM has a bulletin of some kind out for this problem. Putting in new Oil pump today. Just hope nothing got hurt inside the motor!!
69LT1Bird
07-17-2010, 07:47 AM
What was modded? Did you have the oil pump out before? O-ring damaged?
acowherd
07-19-2010, 06:11 PM
Car is camed and procharged. Oil pump was not taken out prior. Did some investigating, and found that ls3 has some issues with check valve sticking open and not building pressure. Replaced with another stock piece that was worked over, and holds more oil psi.
ThunderZ28
07-20-2010, 02:54 PM
this happened to me and trashed the whole motor...
I went back with an LS3 416 stroker motor.
ULTIMATEORANGESS
07-25-2010, 07:22 PM
this is not good news. i hope youre engine is ok.
acowherd
07-25-2010, 11:33 PM
Well I put 500 miles on it since the new oil pump, and everything seems to be ok. I did find that the procharger has a bad seal, and sent it off for repair. When everything gets put back together, track time will in it's future.
ttranssam
07-25-2010, 11:43 PM
good thing you caught that before it killed that motor!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
