Port and Polishing
Port and Polishing
So I decided I am going to buy a Fast Intake (most likely a Fast 90) and throttle to go along with the 243 heads and the cam I plan on purchasing as well. With that being said I want to port and polish the heads and intake along with a throttle body to give me the best flow and performance upgrade possible. I want to do it myself, but have never done one before. I did some research and got bits and pieces of what I need. My question if for those of you that have done this how hard is it and how did you do it? From what I saw I thought a dremel would work. Are there any exact numbers that I should be spacing certain areas to or anything like that? Sorry if I sound like a noob but I want to do this right and I don't really feel like dropping $2,000+ on something it looks like I can do. Thanks.
-Dan
-Dan
don't polish the runners.buy some cheap 853 heads for $50 to practice on.go to ls1hardcore.com to see more pics of home ported heads.you will love porting your own heads,it takes some time to get it right.
i did my first set of ls heads last winter and i just went off of pics and suggestions off this site. They flowed very well and it wasnt that hard at all to do, just time consuming.
A household dremel wont work well for porting though. you need to either go with a good air die grinder or a name brand 1/4" electric grinder.
Buy yourself a couple of different carbides and lots of cartridge rolls.
https://ls1tech.com/forums/generatio...d-porting.html
