tire width on 9.5" wide rim
Old 07-17-2010, 04:05 PM
ncfastls1's Avatar
Default tire width on 9.5" wide rim
I hate to make one of these little topics that I'm sure have been done thousands of times but I want to make sure before I buy. I need new tires for my front 17" C6 Z06 replicas with a 9.5" width. Now I've been using a 245/45/17 because that's what it recommended when I bought them but it's way too small. There's a noticable gap between the tire and rim (and now my rims are dented to hell!) My rears were the same way using 275/40/18 until I bumped up to 295/35/18 and now they fit tight as a glove. With the fronts I was going to go 265/40/17, but I read in the sticky above that a 275 would be ideal. Is that stretching the limits on the width or would a 265 do just fine? Is there any benefits of getting a wider tire up front? I do some pretty spirited driving and the edges of the tire always wear out much faster than the rest of the tire.
Old 07-17-2010, 04:07 PM
Gordo78's Avatar
I would go with a 275. You should be able to run a 265 no issues as long as its on the fronts.
Old 07-17-2010, 04:49 PM
NVR_SPDS's Avatar
I would run a 275 as well. They fit a 9.5" wheel nicely, and they may actually be cheaper than the 265s. Youll have more tire options, since its a very common size as well.
Old 07-17-2010, 08:37 PM
someday's Avatar
275 is the recommended size for a 9.5" wheel
Old 07-18-2010, 09:43 PM
Xsta Z 28's Avatar
275/40R17 is the perfect tire for that wheel.
Old 07-18-2010, 10:37 PM
9WhiteCamaro9's Avatar
try 285/40/17 when i need new tires thats what imma get to have a lil wider tire instead of the 275/40/17 that i have on there now and to have a lil better protection to the wheels as well
Old 07-19-2010, 06:02 AM
meine96ws6's Avatar
i was running 275's on all corners. and they fit fine..
Old 07-19-2010, 10:20 AM
Empatho's Avatar
Do you happen to have any pics of how the 245 look on the front?
Old 07-19-2010, 10:40 AM
$750 L98's Avatar
275/285 will look and work great. My 1995 C4 'vette came with 285/40/r17 on 9.5" wheels out back.
Old 07-19-2010, 11:18 AM
Detoxx03's Avatar
275 would be big enough for the front. I've seen people run a 295 in the rear on a 9 and 9.5" wheel with no issue.
Quick Reply: tire width on 9.5" wide rim
