Mallory window switch wiring ??
Anyone have a diagram or instructions for wiring this window switch up? I've got a TNT wet kit w/ a FPSS and can't figure out how to wire the window switch into the circuit. Any help is greatly appreciated.
Thanks
Jman
Thanks
Jman
Thanks
Jman
Thanks
Jman
Go to MSD's website. Download their PDF file on the MSD 8956 window switch. For LS1's you need to cut the red and blue wire loops. I believe if you have a 98 LS1 you tap into the #35 wire in the bottom PCM wire bundle. If you have a newer car you tap into the #10 white wire for the tach. Do some more research with the search feature. That's what I did. I'm waiting on a window switch for my car. Good luck
I'll see if I can find mine.
