stroker question
Old 07-18-2010, 05:34 AM
andrew(02ss)'s Avatar
Default stroker question
if you're building a 408 will you have to get the block clearanced for the added stroke or will the rods clear everything?
Old 07-18-2010, 09:15 AM
batboy's Avatar
Most of the time you will need some minor clearancing. You should always check or have a machine shop check.
Old 07-19-2010, 07:56 AM
1SLwLS1's Avatar
Give the machine shop your block and the rotating assembly.
Old 07-19-2010, 10:49 AM
KCS
Moderator
KCS's Avatar
2.00" small journal rods would usually clear, but the 2.10" pin usually needs a little clearancing.
Old 07-20-2010, 08:17 AM
got a compstar with 2.1 rod journals..
thanks for the info
Quick Reply: stroker question
