11 Second Club - Happy Days
ALZ28
07-18-2010, 01:44 PM
AT LAST(after 2 years of crap mail order tuners:ripped:) with help from Ed Hutchings from VA with tune, finally:D
11.94 @ 114
More to come on next test day in August as he has found other faults in tune on fuel side since this run. It was running 13.95ish AFR at WOT creating 2-3* KR as well.
And best of all it idles like a dream.
blk/slvr02ss
07-18-2010, 02:26 PM
Get your 60ft down in the low 1.6's high 1.5's and u will be running mid 11's.
ALZ28
07-19-2010, 11:50 AM
I am hoping for an 11.7 with latest tune adjustments
Other problem on all 3 runs was it shifts at about 5700 1-2 shift when its set at 6200. 2-3 is about 6100 which is ok.
I see you have same SS3600, what rpm do you launch at? I have been leaving off idle so far
McLeod
07-19-2010, 01:26 PM
Good job. Ed is well known on both sides of the Atlantic.:chug:
ALZ28
10-25-2010, 03:53 PM
update as in sig. ran a 11.74 @ 116 n/a, then 3 weeks later wouldn't better 12.06 @ 113, so put N2O on and it ran 11.57 @ 118 with 75 shot
since found a faulty TPS, which was showing peaks and troughs in log from 100% down to 47% without me lifting. fitted new one, now idle has gone crazy!! time for Ed to work his magic again.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
