Stock/rims and tires question
What is the largest size tire I would be able to fit on stock 17" rims on a 2002 Camaro SS?
There are the rims I have, just in case you need to know that >_>
Camaro & Firebird Fitments
Bolt Pattern
5 x 4.75" or 5 x 120.65 mm
Lug Nut Size
19 mm socket (6 sided socket preffered over 12 sided sockets) 3/4" will work in a pinch.
12 mm X 1.5 pitch commonly marketed as M12X1.5 - Recommend a "Bulge Cone Seat" style lug nut.
Wheel Fitments
The numbers in the columns are as follows:
WIDTH ..... OFFSET ......... WIDTH OF TIRE
Front and Rear
7.0" ..... +35 to +40 mm .... 215, 225, 235
7.5" ..... +35 to +45 mm .... 215, 225, 235
8.0" ..... +38 to +55 mm .... 225, 235, 245
8.5" ..... +38 to +45 mm .... 235, 245, 255
9.0" ..... +38 to +56 mm .... 255, 265, 275
9.5" ..... +38 to +56 mm .... 255, 265, 275, 285
10.0" ... +38 to +48 mm .... 265, 275, 285
REAR Only
10.0" ... +38 to +54 mm .... 275, 285, 295
10.5" ... +38 to +50 mm .... 285, 295, 305, 315
11.0" ... +45 to +56 mm .... 305, 315, 335
Bolt Pattern
Lug Nut Size
Wheel Fitments
Front and Rear
REAR Only
