LS2 chain on ls1 sprockets
Quick question. Tried searching for several topics but I could not find a direct question. Will an ls2 chain fit on stock ls1 sprockets with no problems? If I bought a new ls2 timing set (chain and both sprockets), would it bolt up to the ls1 crank? Im 90% sure it will but some reassurance from someone who has done it would be great!
Thanks
Chandler
Thanks
Chandler
LS1Tech Premium Sponsor
And, just to add a bit more info to the thread for people who might search and find it down the road....you can use the LS2 cam gear on your LS1 engine as well without any problems. The LS1 and LS2 crank gear are the same part.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes, if you try to order an LQ chain at the dealership, you'll get the LS2 chain as John@SDPC stated.
__________________
LS1Tech Sponsor
Normally they have problems when you use a low quality dampener/harmonic balancer. Usually they have no dampening material so the chain takes all the bad hits that the engine can throw at it. Not a good thing. I would put a tensioner on the block if it has provisions for it definitely.
LS1Tech Sponsor
Switch to which chain though? From GM you will only get THAT chain. If you are talking about some other set, then its up to them. The GM chain, you can run with or without. It does not matter too terribly much. For a higher HP build, I would find a block that has provisions for it though.
