Notices
WTB: LT1 Cam
Old 07-19-2010, 06:39 PM
LSWHO's Avatar
Default WTB: LT1 Cam
Purchased
Old 07-24-2010, 10:26 PM
LSWHO's Avatar
Nobody? Ready to buy fellas.
Old 07-25-2010, 09:22 PM
Bowtie4life's Avatar
I've got a fresh crane 227 still in the box, never installed, only thing is I might have miss placed the cam card when I moved. Summit wants $419.95, the cam is also a billet cam. $250 shipped?
Old 07-26-2010, 03:58 PM
here are the specs on the cam from summit, I tried to get them from crane's website, but it's not working.
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,000-6,000
Intake Duration at 050 inch Lift 210
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 210 int./224 exh.
Advertised Intake Duration 272
Advertised Exhaust Duration 286
Advertised Duration 272 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.479 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.518 in.
Valve Lift with Factory Rocker Arm Ratio 0.479 int./0.518 exh. lift
Lobe Separation (degrees) 112
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Computer-Controlled Compatible Yes
Grind Number 2033
cam is in perfect shape, and the pin is the correct length for 95-97 lt motors.
Old 07-26-2010, 09:26 PM
LSWHO's Avatar
That's too much for me for a shelf cam. Thanks tho.
Old 07-26-2010, 11:59 PM
formerly 2004RST (changed 11/19/2012)
OneQwikSS's Avatar
have a stock LS1 cam...make an offer
Old 07-27-2010, 05:53 PM
LSWHO's Avatar
I can't say for certain, but it appears you completely ignored not only most of the thread title, but pretty much my entire post too.
