Need help finding ignition relay
Location: A little bit of everywhere thanks to Uncle Sam
I believe my ignition relay has gone bad. I was having the typical symptoms of car starting some time and not starting other times. Now it won't start at all. I would like to replace the ignition relay to see if this remedies the problem. The only problem is when I look in the glove box, I can't find the darn relay!!! Any pics or write-ups would help. This has been nagging me for almost two years!!!
Check your user manual if you can't find it.
