Gears & Axles - Stock Rear end question
Gohard
07-20-2010, 03:57 AM
I have a 02 M6 trans am. The guy I bought the car from was saying something about this car has a better rear end. Was there any other factory options for the rear end? I know they're all 10 bolts but something about a auburn rear end comes to mind. He said this car is not an auburn, it's something else. Would someone please help me find some basic info on that?
SS4Luck
07-20-2010, 04:10 AM
Theyre are choices to upgrade the carrier and the posi they dont make it much stronger as far as handling much more power, but its a little safer if you stay on street tires with basic bolt ons
Gohard
07-20-2010, 04:56 PM
How do I know what I have exactly in my rear end?
SS4Luck
07-20-2010, 05:05 PM
you could poossibly pull the diff cover and drain everything and look and see. If not its gotta come out and apart so you can see part numbers. Im not exactly sure how you would tell, i just know there were upgrades you could to to a 10 bolt
Gohard
07-20-2010, 05:38 PM
It was either the auburn or something else with "m" I think? I have the 2002 brochure at home. It should be in there, I don't know why I didn't think of this earlier. Thanks
LS1W66
07-20-2010, 05:50 PM
Early Cars had Auburn's later cars have Torsen's. My `98 has an Auburn with 144K miles, although I did replace gears (I broke them) the differential is still holding strong.
Jays_SSZ28
07-20-2010, 06:23 PM
As far as factory options there is the Auburn and Torsen.
The easiest way to tell the difference is to jack the rear tires off the ground, with the trans in park, or a manual trans in gear, spin one tire.
With an Auburn the other tire will spin the same direction, with the Torsen the other tire will spin the opposite direction.
The only other factory rear end option was an AAM aluminum cover that directs more oil to the axle tubes for better cooling and lubrication.
Gohard
07-20-2010, 06:29 PM
That's what I was trying to find out (factory options) Thanks!
Gohard
07-20-2010, 06:31 PM
Hey! Are you on mifbody? I know I seen that pic in your sig on that site.
skanknova
07-21-2010, 04:11 PM
the 7.5 10 bolt is junk dont waste a dime on it
LS1W66
07-21-2010, 06:19 PM
Yes sir me and the Admin/Owner of that site go way back. :hijack:
You should come out to Woodward one of these weekends.
Gohard
07-21-2010, 06:31 PM
Mannn just give me a time and a place! :)
LS1W66
07-21-2010, 06:50 PM
PM sent.
