93 coupe, whats it worth
Old 07-20-2010, 02:11 PM
93sspcoupe's Avatar
Default 93 coupe, whats it worth
i got a 93 ssp car in electric red. it has a a 347 10.5.1 compression. comp 282 cam pro comp 175cc heads edlebrock rpm 2 intake 75mm t bodie pmas mass air, 30lb injectors. bbk longtubes off road hpipe flowmasters. 94 v6 altenator. 2 1/4 turn lock to lock rack and pinion. kyb shocks and struts, stock coil springs that have been cut. maximum motorsports lower control arms and caster camber plates. 5 lug swap with mach1 front brakes and 99 cobra wheels. 355 gear. tremec tko500 spec stage 3 clutch and billet steel flywheel. i can into more indepth detail if asked.
it is a true ssp. has 160 speedo with a million mile tripometor "only offered in 93 ssps" its the one in my avatar.
i been thinking of selling it for something different
