Callies stroker crank too cheap?
Old 07-20-2010, 09:21 PM
bp944's Avatar
Default Callies stroker crank too cheap?
Any opinion on Callies stroker cranks? I mean they're really cheap but I doubt that price pays for a whole lot. Am I wrong?
Old 07-21-2010, 01:00 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
I've never read anything bad about Callies cranks other than their wait time on custom units. Why do you think their prices are cheap? What are you comparing them to?
Old 07-21-2010, 01:04 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Lunati....LOL!
Old 07-21-2010, 02:08 AM
Pwebbz28's Avatar
If using a 4 bolt head you are going to push water before you need to worry about anything stronger than a compstar crank.
Old 07-21-2010, 02:26 PM
Silver408z's Avatar
Callies has 2 forge cranks. 4030 or what and a 5120 or something like that. The 5120 is about 200 dollars cheaper. Maybe he is seeing that. Yes its a 4" stroke. I talked to Erik at HK about this crank. He said its good for NA and even small nitrous shots. Both are good just depends on your goals.
Old 07-21-2010, 03:51 PM
OWN3D BY MY PROF!
Originally Posted by orangeapeel
Lunati....LOL!
I was thinking custom center counter weight billet Sonny Bryant, but I guess it's all relative to the cubic dollars in your wallet.
Old 07-21-2010, 03:53 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
I'd put their 5140 cast crankshaft alongside Eagle and the other budget cranks as far as machining quality and all. Don't be horribly shocked if it needs turned to make those journals perfectly round....we have seen it fairly frequently with the Eagle and Scats too.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 07-21-2010, 04:23 PM
427's Avatar
The center counterweight Callies billet is simpler to install and priced about the same as the sonny stuff.
Kurt
Old 07-21-2010, 10:24 PM
OWN3D BY MY PROF!
Kurt
That's nice to know. All I've heard about them is that they're impossible to get on any sort of time line.
Old 07-22-2010, 06:14 AM
427's Avatar
If you are looking for common stroke stuff they have a plan to stock those. The custom stroke stuff may be a little wait, but that happens with Sonny also. The Callies has a taper in the center weights that saves a bunch of work fitting the crank in the block.
Kurt
Quick Reply: Callies stroker crank too cheap?
