CAM suggestions!!!
Old 07-20-2010, 11:28 PM
88rx7v8's Avatar
Default CAM suggestions!!!
looking for any suggestions on cams for my 30 over lq4 with dome pistons and a milled 317 with full port and polish and valvetrain upgrade.should i go costum or go with whats out there.
Old 07-21-2010, 12:52 AM
In-Zane Moderator
ZONES89RS's Avatar
I would like to know what my 6.0 with a Trex would do if i had pistons and ported heads, but that setup, think that PatG would be able to tell you what would work best.
Old 07-21-2010, 08:27 AM
LS1 Tech Administrator
Patrick G's Avatar
There is probably a shelf cam that will work. The only problem is figuring out which one to use. Lots more info is needed before a cam is to be selected though. Your cam guy will need static compression numbers, head flow, intake manifold choice, spring preference, exhaust type and size, rpm range, power adders, etc. You always get your parts then select your cam and pushrods last.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 07-22-2010, 08:36 AM
88rx7v8's Avatar
ok,it will also ave the ls6 intake manifold and for exhaust stock c5 manifolds,patriot double springs rated at .650,heads flow .282cfm at .600 lift with stock valves
Old 07-22-2010, 01:39 PM
brian_rs/ss's Avatar
wtf? ls6 intake and stock manifolds? why are you spending money on a cam and not at least buying a good set of headers?
Old 07-24-2010, 10:06 PM
88rx7v8's Avatar
header too damn expensive and hard to fine especially for my car,besides just want to get it running and at least break 400whp
Old 07-25-2010, 02:50 AM
shorties and a single plane. problem solved.
