PTV and 241s/243s
Source:
http://www.smokemup.com/tech/ls1.php
The 243 will be ever so slightly less, the 243 had a 64.45cc chamber and the 241 had a 66.67cc chamber.
Source:
Source:
If it has the solid valves, then no, it will not change. The solid valves should have the same valve drop as the 241s. The chamber is smaller around the sides, not in height. I have heard that the lightweight valves are a little longer and may affect PTV, but since I have not used these, I cannot confirm. The 243/799s with the solid valves, should be exactly the same.
the valves would be longer on the spring side of the head, not inside the chamber. I have both sitting in my shop, I'll take a look.
I'm going to say that the PTV should stay the same, as the chamber is smaller on the spark plug side, and starts to create a 2nd squish pad. Which leads me to believe that the valve clearance will be the same. However, I will double check.
it is a 230/234 .600/.602 111+4 on eps lobes
I really appreciate it. I thought this would be common knowledge since this is such a common swap.
The only reason the ls6 (hollow/sodium) valve is longer is to make up for the smaller base circle cam, and since the installed height is the same, its only the tip they lengthened.
Anyways, I just weighted one of the 243 intakes, its not a lightweight one, so I have no way to accurately verify the above, however, I'm pretty sure I'm right.
Back to the original question of 241/243 PTV clearance, They are the exact same, stock for stock. Any valve work with stock valves should give you a tiny bit more, any milling will reduce your PTV by the same amount as milled.
This I just verified ^^^
Yeroon
Yeroon
Yeroon
Yeroon
That's what I figured. Thank you VERY much.
Yeroon
Yeroon
This is your best answer!
