Sponsor Group Purchases - BMR Fabrication Reduces Prices for Differential Bushing Kits (BK001)
BMR Suspension
07-21-2010, 01:35 PM
Money is tight for everone, so BMR Fabrication is making it easier to improve the performance of your 2010 Camaro and Pontiac G8 vehicles by cutting prices on the Street version of our Differential Bushing Kit (BK001). The new price for this item is $69.95, which is reduced $20 from the previous BMR price.
This is not a sale price…this is the NEW low everyday price from BMR.
Here are some features and benefits of the BK001 Differential Bushing Kit (Street Version):
•Low deflection polyurethane provides additional stiffness over the stock bushings
•Manufactured from 68 durometer polyurethane for a quiet ride
•Less bushing deflection provides better handling on the street or at the autocross track
•Improved launches over the stock bushings at the drag strip
•Inner sleeves are zinc plated for corrosion resistance
•Fits SS or V6 Camaros and Pontiac G8s
•Proudly Made in the USA!!
•Same day shipping – product is boxed-up and Ready to Ship!!
•2 year warranty
Compare these design features to differential bushings from other manufacturers:
•The BMR bushing has a thrust surface on both sides. Under normal driving conditions, the thrust surface does not contact the differential mounting bracket. However, under hard cornering maneuvers or hard launches, the thrust surface contributes additional rigidity. Other manufacturer’s use a bushing with a thrust surface on one side only.
•The BMR bushing thrust surface is square with the differential mounting bracket. Some manufacturer’s cut back their thrust surface, which provides less support during hard cornering or hard launches.
The BMR Differential Bushing Kit is almost $50 less expensive than competitive products.
Why pay extra for an inferior bushing kit????
This product can be ordered directly from BMR Fabrication by calling (813) 986-9302 or you can order online : CLICK HERE (http://www.gnetworks.com/v4/go.gnf?session=bfd573e2a20df55ae822899b23bafcaf&s=bmr&t=&product=162642&n=default&d=products&listTemplate=)
BMR Fabrication – Highest Quality, Strongest Product, AND Lowest Prices!!!
http://www.bmrfabrication.com/ForumImages/BK001forum.jpg
