How to adjust headlight?
I bought some headlights from a local guy to replace my old ones, the drivers side went on fine and then i noticed on the passenger side the headlight adjusters (where you need the hex wrench or alan wrench or something) were turned all the way out... i guess he thought he needed to do that to get them out or something
they were so far out that i couldnt get them to turn back in so i took off the back assembly from my old headlight without adjusting anything and put it on the back of the new headlight thinking it would be at the same level as the old one... unfortunately the passenger side shines noticeably higher than the drivers side
of the two adjusters on the back, which should i be trying to adjust to bring it back down?
Save the manuals!
Having the passenger side higher is normal. It should be pointing straight ahead and the driver's side should point down and in. This is so cars don't blind oncomming traffic.
If you are out of alignment, a good mechanic shoud be able to adjust you for a low fee. The GM factory manual also has a milti-page procedure to do it yourself but it's a major PITA.
