Best place to mount fuel pump??
Old 07-21-2010, 05:32 PM
AChotrod's Avatar
Default Best place to mount fuel pump??
Wheres the best place to mount the fuel pump for a rear stand alone fuel system? Trying to do this tonight. Can/Should I keep it in the trunk or mount it outside the car? Closer to the cell the better correct??
Thanks
Mike
Old 07-21-2010, 09:53 PM
AChotrod's Avatar
No worries Ill get er done!
Old 07-21-2010, 10:01 PM
1badzee's Avatar
In-line I assume?
Old 07-21-2010, 10:22 PM
SPRAYED Z's Avatar
Outside under the car
Old 07-21-2010, 11:21 PM
hashtagBMW
Speed Density's Avatar
Magnafuel 4302
Shake n bake:
And it may/may not help, but here is the return to the tank:
Old 07-21-2010, 11:35 PM
AChotrod's Avatar
Thanks ^^^ Thats exactly my plan to mount it.
Old 07-21-2010, 11:44 PM
hashtagBMW
My sump is on the right rear of the tank, its -12AN. If I did it again, Id do a sump with feed/return right in the middle but I had a saga with this setup so I left it.
Tony.
Old 07-22-2010, 01:14 AM
suicidal racing's Avatar
Im using -8 bulk head fitting then a 90 off that into a filter that i have attached to my fuel pump the i run the line in the stock postion..i made a bracket that holds my pump..it is attached to the back side of the fuel tank hump.
Old 07-22-2010, 10:43 AM
quik95lt1's Avatar
I put mine in that little cavity under the drivers side rear seat under the car...tucks up in there nicely so nothing can hit it and it fits perfectly. Ill take a pic at lunch and post it up.
Old 07-22-2010, 11:12 AM
AChotrod's Avatar
Thanks guys.
I have a 3 gallon alum fuel cell that will be mounted in the trunk inline pump and aeromotive regulator, Think Im going to mount the pump where Tony has it, but would like to see the pics of it under the seat.
Also where you guys putting the regulator?
Old 07-22-2010, 12:24 PM
quik95lt1's Avatar
well im a moron i went home and completly forgot to take the picture lol......ill take it tonight as for the regulator heres a pic of that and how i got everyting plumbed on mine....came out pretty good i think.....
Attached Thumbnails Best place to mount fuel pump??-dsc00132.jpg   Best place to mount fuel pump??-img00438.jpg
Old 07-22-2010, 12:46 PM
AChotrod's Avatar
Looks good and I like the valve covers!!
I think Im going to mount the regulator to the frame rail where the ABS used to be. I think its the closest to the noids I can get and keep it clean, plus its a nice flat spot and should fit pretty good. Cant wait to get off work and go back to work on the car.
Old 07-23-2010, 08:54 AM
quik95lt1's Avatar
ok here ya go sorry it took so long lol
Attached Thumbnails Best place to mount fuel pump??-2010-07-22-23.58.03.jpg   Best place to mount fuel pump??-2010-07-22-23.58.14.jpg   Best place to mount fuel pump??-2010-07-22-23.58.29.jpg
Old 07-23-2010, 11:01 AM
hashtagBMW
That's where a lot of people put it. I wanted my "sucking" side to be close to the tank for less work on the pump (and in turn heat). That's why mines where it is.
Old 07-23-2010, 02:46 PM
SoxXpupPeT's Avatar
Wow reading up on this thread really makes me want to do an external fuel pump! awesome stuff!
Old 07-23-2010, 03:57 PM
yep pumps are ment to push not pull...i always mount mine with in a foot of my rear tank oulet
Old 07-24-2010, 12:32 PM
AChotrod's Avatar
I also wanted it close the fuel cell. I ended up putting it on the DS between the trunk and frame rail. Yesterday I picked up 40ft of braided line and started plumbing it up. Who knew 40ft would not be enough anyways I have the fuel cell in the trunk then drilled a hole on the DS of the t-top well/trunk connected to the pump. Then it and return line follow the factory fuel lines. Im going to run the lines over the plastic wheel well liner to where a factory air box would be and mount the regulator right across from the fuse box. Should look pretty slick when its all done.
Old 07-25-2010, 06:11 AM
damn you used 40ft of line holly ****..mine is set up as a dead head and i got everything laid out an 20ft is more then enough for me.
Old 07-26-2010, 12:51 PM
AChotrod's Avatar
Its a 3gal stand alone in the trunk, that basically runs with the factory fuel lines from the stock tank forward, then over the drivers side fender liner and up into the engine bay then to the regulator I mounted right across from the fuse box. I was stunned also it took that much but also includes the return line
Also I have a a1000 regulator what do I do with the vacuum port?
