do 98-02 camaro headlights have relays?
Old 07-21-2010, 10:41 PM
Crimson's Avatar
Default do 98-02 camaro headlights have relays?
My low beams dont work sometimes and my highs are always fine. I can't find out if their is a relay them on the forums
Old 07-21-2010, 10:49 PM
SparkyJJO's Avatar
Actually these cars do not. All the power for the headlights goes through the headlight switch. Yet we have a relay setup for the fogs... go figure.
Old 07-21-2010, 10:50 PM
Breathing Fire's Avatar
Check the grounds. More than that check the ground in the harnes. Both not work at the same time? If so ground wire driver side harnes is the problem, I think. Had the same issue when I first got my car. Sometimes they worked and sometimes they wouldn't. Accidently bumped the harness and ding lights came on.
Quick Reply: do 98-02 camaro headlights have relays?
