LT1 Stall Converter
Old 07-22-2010, 02:51 PM
logan2116's Avatar
Default LT1 Stall Converter
What is the best stall converter for my stock 95 Trans Am will be doing mods in the future like cam gears full exhaust etc? i will be having my 4l60e tranny built to support 500 hp with a shift kit as well dont know what stall size i should go with please help thanks people tell me i should go with a 2000 or 2500...
Old 07-22-2010, 03:12 PM
brucer's Avatar
i bought an lt4 hotcam cheap, and i bought a 2500rpm stall and put it in the car with the stock engine and trans and rear gears..
even if i dont use the hotcam which i'm thinking of going to a lunati voodoo cam i'll still have a good stall for the cam i will choose..
look at what cams you would pick to run in the future and pick your stall accordingly..
i do know if you go over 2500rpm stall you start paying alot more money for stalls.. i bought a Champ 2500rpm converter, from Champ Converters in Evansville Indiana, it cost $150 plus your old converter for a core. i think it would be hard to beat that stall for the price.. i would definetly use a champ converter before a b&m,tci,hughes..
Old 07-22-2010, 03:17 PM
lt1-xjs's Avatar
I run the Yank SS 3600 with just bolt-on's. You won't be disappointed.
Old 07-22-2010, 03:19 PM
Badazz 97 TA's Avatar
anything over 3000. Dont go any lower
Old 07-22-2010, 03:21 PM
WhitePhoenix99's Avatar
Don't skimp on the converter. .
Give one of the sponsors here a call and tell them your setup and your goals for the car and they will hook you up.
http://www.circledspecialties.com/
http://www.converter.cc/
Old 07-22-2010, 03:22 PM
96lt1m6's Avatar
Spend the cash on a good converter,if they break the generally ruin the trans..not all the time but it has happened!
3200 minmum
Yank
Vig
Circle D
Edge
Midwest
Old 07-22-2010, 03:31 PM
chevy94c's Avatar
Go with vigilante 3200 stall. Plus you get one free stall change. So when you get head and cam package you can get that for free.
Old 07-22-2010, 03:47 PM
TheTransporter69's Avatar
i like my yank ss3600 drives good and isn't to much stall(lots of people told me that before i put it in.)
Old 07-22-2010, 04:09 PM
Moderator
BizZzatch350's Avatar
I had a Vigi 3200 and it was great.
Old 07-22-2010, 04:21 PM
4K+Converter's Avatar
I'd wait until you get a cam to get a converter and get them matched together to get the most out of both.
Old 07-22-2010, 09:54 PM
robsquikz28's Avatar
Hell NO ^ even stock engines benefit greatly with a 3k stall
Old 07-22-2010, 11:07 PM
1badzee's Avatar
I hope you know you're on your own there
Old 07-22-2010, 11:56 PM
I completely disagree, its a huge trade off for mediocre gains on the stock motor.
For my old LT1 car I saw the LS1 guys throw huge converters at their cars and wanted to get out of the hole hard like they did and got a Vig 3200, which flashed more like 4000.
It went from a 13.5 car, to a 12.9 car on ET Streets, it also went from an average of 24 mpg to 15 mpg, and it sucked to drive on the street.
A friend of mine who also had a stock motor LT1 in his car had some no name 2400 converter. It felt way better on the street, he ran 13.1 on street radials, and it wasn't nearly as thirsty.
So I did the sensible thing and threw a big cam at it, and the CC306 was the only over the shelf cam I had to pick from way back then. It ran 12.3 with untouched heads and luckily for me the converter was the right size for the job.
Later I got more cash and threw some LE2 heads at it, and I didn't have enough converter any more, the car had a dead spot from 4-5k. I sent it back to Vig and when it came back it flashed around 5000. 11.4's all motor in good weather.
Little did I know, but buying a converter, then doing a cam, then adding heads after all that was completely the wrong order to to things. Because of that I had to spend more money on the converter to get it where it needed to be.
The correct way to build a motor is to decide what rpm the motor is going to spin and pick heads and cam to meet your goal, and then choose the correct converter that matches the combo.
That all hinges on if Logan's car is going to see more track or street use. Mine was a daily driver, most of the time it was on street radials and I couldn't take full advantage of having a huge converter in the car.
Old 07-23-2010, 01:39 AM
96lt1m6's Avatar
when you begin modding a car and staying N/A are you really concerned with fuel mileage?
if you want fuel mileage leave the car alone or get a driver!
Old 07-23-2010, 01:44 AM
+1
Lots of guys drive big stalled auto's daily and don't have a problem with it and benifit greatly at the track.
If you're worried about gas mileage you're in the wrong hobby.
Old 07-23-2010, 03:40 AM
hitmanws6's Avatar
I read nothing but good things about the SS3600, many people say its the perfect converter with 3.73s. I have yet to try mine out
Old 07-23-2010, 04:30 AM
Originally Posted by WhitePhoenix99
+1
For some people its a valid concern these days and they may not be fully informed on what they're getting into with a big converter. Back in college when premium was $1.19, 12 mpg wasn't a big deal. If I were a poor college kid today, I wouldn't want to drop $700 on a converter only to find out my gas mileage was cut in half. Luckily that's not a big concern for me anymore, and when my 496 gets finished it will probably get 6 mpg at speed.
I'm just presenting all the facts so he can make a informed decision on what to do with his car. From my experience, it was a mistake to do a big converter in a LT1 car without a cam to match.
Old 07-23-2010, 08:15 AM
quik95lt1's Avatar
agreed id say either the SS 3600 or a 3200-3600 vigilante. as for drivibality it will be fine I'd just throw an external cooler at it for some insurance. hell i've been driving a 4000 on the street with no problem at all, as a matter of fact as of next week ill be driving a 5000 on the street
Old 07-23-2010, 09:08 AM
stumprrp's Avatar
honestly, if you REALLY want to know i would dyno the car, find the peak torque and pick a converter that is at or a little lower then that, with a stock LT1 this should be around a 3600.
i have a 396 and peak torque is still around 4800 with a fairly small cam (236/244) anything over the stock cam i would use a 4000 stall.
Old 07-23-2010, 11:49 AM
irocurpony8489's Avatar
i installed a ss3600 in my buddies ls1 with 3.73 gears it was the best driving high stall converter i ever drove. Drivablity was great with the 3.73 gears hardly noticed it till you stomped on it. It cut 1.69 60's with nitto drag radials. FTI and circle d also have really good results and good customer service. I plan to go with circle d 3c in the fall.
Quick Reply: LT1 Stall Converter
