valve clank with video help
Old 07-22-2010, 03:13 PM
RED PUNISHER Z's Avatar
Default valve clank with video help
ok i got some new rods and put them in i adjusted the rockers with 1/4 turn past zero lash and set the lock i turned on the motor and now it makes a clank or knocking sound after i rev the motor some times ....did i not adjust the rockers right do they need to be 1/2 turn past zero lash i have readjusted them 2 times already and still the sound is still there it never made this sound before when the car was running i got new rods because one of them had bent ....in the video i rev the motor 4 times the 2nd time it clanks a bit but you cant really hear it in the video and then the rpm drop a bit then goes back up and on the 3rd rev you can hear it clank or knock like 4 or 5 times what is making that sound and how do i fix it
<object width="550" height="400"> <param name="movie" value="http://someyoutubevideo"> <embed src="http://www.youtube.com/watch?v=Ijiub6Cg4yo" width="550" height="400" type="application/x-shockwave-flash"></embed> </object>
Old 07-22-2010, 03:20 PM
Badazz 97 TA's Avatar
Did you adjust when the lifter was on the base of the cam. piston at top dead center on the compression stroke?
Old 07-22-2010, 03:23 PM
pyro719's Avatar
Just do the engine running method. loosen one rocker at a time untill it starts to click and then tighten until clicking is gone and then 1/4 turn past that ad you should be good to go.
Old 07-22-2010, 03:25 PM
yes i did...i did it with the motor off starting at the #1 cylinder and following the firing order and turning over the motor waiting for the intake lifter to drop then set them to zero lash
Old 07-22-2010, 03:27 PM
its hard for me to do it with the motor on because the rockers are really noisy it hard for me to tell
Old 07-22-2010, 03:28 PM
but my real ? is what is making that clacking sound i know the rocker tick and the valves ping so what is making that sound
Old 07-22-2010, 03:33 PM
pyro719's Avatar
Sounds like loose rockers to me. You need to get them all tightened down enough to not "clack" And then you will be able to start your adjustment.
Old 07-22-2010, 03:53 PM
i so a lose rocker will sound like that listen close after the 3rd rev you can hear it after i rev the motor i guess ill do a bit more than a 1/4 past zero lash if i over tighten them what will it do so i know what to look for
Old 07-22-2010, 07:53 PM
any one else ??? lisen to the video it happend from .32 to .33 you can hear it clank is it a loose rocker or some thing else
Old 07-22-2010, 08:13 PM
The link wasn't working earlier but i finally was able to listen to it. Your rockers sound fine. The noise your describing at the .32mark sounds like the bottom end IMO.
Old 07-22-2010, 08:50 PM
pyro719's Avatar
I run the crane gold sa rocker which are supposed to be one of the noisier rockers and mine are no where near that loud.
Old 07-23-2010, 12:31 AM
so do i need to set them more than a 1/4 turn past zero lash ?.. i let the motor cool down to see if it made a difference and it did no clanking sound ...when i took the video it was up to temp and how can it be the bottom end the motor was fine before i took the intake and valve cover off and the motor has only about 700 miles on it
Old 07-23-2010, 12:34 AM
and before i took off the rocker they where that loud too i did not put them in the original owner did
Quick Reply: valve clank with video help
