T-56 Fresh Rebuild Hard To Get In Gear
HI guys I'm posting this for a buddy of mine he just rebuilt his t56 with a tick stage 2 kit, gm slave, pilot bearing, and ls7 clutch kit. We put it all back it in and the car drives fine no grinding or anything but when you put the car into gear, any gear for that matter it will act like it hits a wall then after a sec slips right into gear. It will do this from a stop into first and on into any gear from any speed. We have not replaced the master cylinder yet and was thinking it could be having trouble with the stiffer ls7 clutch seeing as its the original one from 01 with 90k miles on it. Anyone else have opinions?
Thanks Dan
Thanks Dan
just an update huys we installed a tick m/c and used the mity vac to bleed through the top of the m/c clutch pedal feels good and is right below the brake pedal on adjustment and it still does the same thing wen going into any gear. Push the clutch in and there almost like a small wall preventing the shifter from goin into any gear for a split second then its fine. any more ideas? revved the car up with the clutch in and car in first and it didnt move at all so it seems like its disengaging.called tick and they said it maybe just the tranny is tight after a rebuild but idk ive never seen one do this.
How many break in miles on the rebuild? What fluid are you running? Sound like you might just be feeling the notchiness of the billet keys and blockers breaking in? If you don't have 500 mi on it yet, just give it time and change out the fluid after break in with a good synthetic.
I have same setup tick stage 2 and tick master but wit a spec clutch and I agree u are prolly just feeling the notchines of the new parts in there my car shifts like butter at high RPMs never had a problem after rebuild.
i just rebuilt my t56 using the same parts as the kit from tick perf and mine did the same thing. after a few miles it loosened right up. now it shifts great and im just using regular dexron III. just put some miles on it.
::Redbird555::
I'm currently having the same issue..other then I used gear box transmission.org stage 2 kit (all else being the same).....I have no idea what fluid the shop put in my rebuild, but I was thinking master cylinder...now after finding/reading your post, has me thinking otherwise. I have 104K miles on the stock MC.
What did your buddy do to resolve this issue...????????????
