Stock PCM or aftermarket stand alone
Old 07-24-2010, 01:18 PM
Turbomike88's Avatar
Default Stock PCM or aftermarket stand alone
I have a LQ4/LQ9 6.0L motor with a 88mm turbo and will be running 80# + injectors can i get away with the stock PCM or should i buy aftermarket
Thanks Mike
Old 07-25-2010, 03:27 PM
qqwqeqwrqwqtq's Avatar
Stock pcm will be fine.
Old 07-25-2010, 05:34 PM
Mike454SS's Avatar
As long as the 80's are high impedance...or as long as you have a driver box if they're low impedance
