General Maintenance & Repairs - any tip to keep the header bolt coming loose ?
killagt
07-24-2010, 05:31 PM
Im going under the car again to tight the header bolt, that connect to Y pipe. Any one have any tip to keep those bolt coming loose ? red threat lock ?
LS-1Z28
07-24-2010, 11:55 PM
lock washers? thread lock will help too...
meine96ws6
07-25-2010, 03:53 PM
i'm thinking the constant vibration is the culprit.. i would use the thread lock first..
killagt
07-26-2010, 12:24 AM
imma put in some red threat lock tomorrow, if it still dont work, imma fking weld it.:D any one did this ? weld the header to Y pipe ?
HotSilverBird
07-26-2010, 12:26 AM
ahhhhummm http://marylandspeed.com/stage-8-locking-header-bolts-gm-lsx-engines-stg8900-p-1006.html
killagt
07-26-2010, 01:21 AM
god dam for the price.:bang:
LS6427
07-26-2010, 01:39 PM
Aircraft safety wire.
LS-1Z28
07-26-2010, 06:34 PM
fuck those :bigun2:
those e clips are the worst things to take off
I'm looking to get these but they're a little more expensive. (If you've ever taken off those e-clips this is a great deal...)
Percy's Split Lock Friction Lock Header Bolts (bottom of page)
http://www.speedinc.com/catagory.cfm?catagory=Exhaust
46Coupe
07-26-2010, 06:42 PM
I have had good success if the split lock header bolts. Not sure if they have them for LS1 engines though. They basically are cut in an X and have an allen screw that splays them out after you torque them down. Rock solid for me on my big block car.
*edit*
Here they are for LS1
http://www.summitracing.com/parts/PHP-21008/
LS-1Z28
07-26-2010, 06:51 PM
*edit*
found them for cheaper... not sure what's the difference other than they are black.
http://www.summitracing.com/parts/PHP-20008/Application/?query=Make|CHEVROLET|Engine+Size|5.7L%2f350
LS14EVR
07-27-2010, 11:10 AM
This is just coming from a newb, but aren't what you guys suggesting the OP use for the attachment of the header to the head? Isn't the OP having issue with the bolts that hold the Ypipe to the headers. Probably flange mount instead of slip joint with clamp. This is just what I'm reading. But could be wrong.
3YLSYKR
03-13-2012, 03:41 PM
Just use stock bolts with loctite on them and you wont have an issue and saves you money.
great421
03-13-2012, 05:21 PM
Nord-Locks are (also) expensive, but they work.
http://www.nord-lock.com/default.asp?url=2.16.37
bayer-z28
03-13-2012, 06:43 PM
^ I ordered a set of Breslin locking bolts when I did my headers in 04, but they got lost in the shuffle and never got installed.
It's $34..... :confused: I blew $90 on locker bolts. back in 04, they were pretty pricey.. back when LS stuff was still pretty expensive.
