Stock pcm help
Stock pcm help
Can i use a stock pcm , i have a 02 lq9 motor and harness , i don't have a pcm which one would be best for me to use , the motor has a 88mm turbo and 95# inj. or should i just buy aftermarket
How do you tune a stock pcm do you us a laptop ??
I'm new to the efi , i always have had carbs
1 Post
You can use a stock PCM - personally, I would, along with a 2 or 3 bar custom operating system... Yes, they are tuned with a laptop using a tuning software like EFILive or HPTuners. The best PCM to use is a #0411.
How much boost are you running? What kind of injectors are they? What is it going in and what kind of transmission?
1987 Mustang notch , boost will be 10-15 pounds , 95# Delphi injectors , powerglide trans
Do you have pix and more info on which on to use of these... 2 or 3 bar custom operating system
Thanks for your info
1 Post
The 2 bar operating system is put into the PCM using the tuning software - and you use a 2 bar MAP sensor and then you can fuel it accurately in Speed Density without a Mass Airflow Sensor. Those injectors may be a bit hard to tune on idle - are they high or low impedence?
