connection c105
Not enough info here, but only 95-97 harnesses have a C105. You probably got a 94 harnesses if you were expecting a C105 and don't have one.
http://shbox.com/1/harness_connector_faces.htm
im sorry i dont know enough about wiring. the body is a 95 the motor wiring harness is a 1995. the body wiring harness i was told was a 1995.
it looks like the plug is mostly for traction control.
Do all 95 body harnesses have this plug or only ones that have traction control.
No, it's not a traction control thing only. All 95-97s have C105, like I said.
the wires aren't even in the harness. i contacted the person i bought it from on here im not very happy.
Edit: well i just found out this out of 94 so i have to pull it back out.
im going to guess the 95 is not the same at the 96-97 forward body harness
